Jake4k
Hi guys,
Stupid reading, no fun, and not worth your time – but I would really appreciate your thoughts!
I am currently dealing with my first Banggoods warranty, and I am having a hard time convincing them that there is a problem with the 4 pcs lipos I just bought.
I am hoping that you guys will help me with the correct argument / or let me know if I am simply wrong! I can live with the loss (very cheap lipos), and I should have moved on much sooner, but the answers I receive from them is simply not okay. E.g. they keep insisting that I should ‘try to fully charge the batteries‘ (losing my mind!).
I need to find out if this is normal / what to expect from Banggood. I also feel like I need to inform you guys, so you won’t find yourself in the same situation.
Products I bought: 4x zop 3s 6000mah lipos from Banggood. https://www.banggood.com/ZOP-Power-...-p-1653139.html?cur_warehouse=CN&rmmds=search
Problems I am experiencing when driving: The batteries have only 6-7 min of total run time before LVC ((2x3s) Kraton 6s, BLX185)) Also, when full throttling on asphalt they will very often go LVC and I have to shut off ESC and power on again (I can then run again). I normally experience double the run time (or more) with my other batteries which are lower-rated mAh.
Problems charging (SkyRC D100 v2, 2x 100W): When I received the batteries, 3 out of 4 were not at storage voltage (they were sub 20%). Maybe this is why they are acting up?
When I charge from low voltage (10%, 3.65v) the charger shows that 2800-3100 mAh have been added. The end voltage is 12.6v and the charge time is approx. 50 minutes (5A). They keep asking me to prove that the batteries are fully charged, my argument is a picture that shows two batteries connected to the charger showing 12.6v, 3000mah added and a charge time of 50 minutes.
When fully charged the resistance is: 12, 12, 15 and 7, 8, 13 (that’s on two of the 3-cell batteries). I use XT60 to IC5 adaptors – I don’t know if these adaptors could cause the high resistance? I have no issues with my other batteries using the exact same adaptors though...
My argument is that these batteries are faulty. They are too far off their stated mAh rating which was 6000mAh and the resistance is too high for new batteries.
I am very aware, that these ZOP batteries are very cheap and by no means a premium battery. Still, they should not be this far from what they are marketed as? Also, I have other batteries, including 3x other ZOP batteries (2x 3s and 1x 6s). I have never had problems with the other ZOP batteries, and the mAh added is way higher even though they are only rated for 5000mAh.
Am I wrong? Are these numbers normal to you guys? Banggood saying, that all the above information is not enough to prove that they are faulty. They just keep insisting me to try to charge them fully :/
I have shown them the same pictures that you can see here. https://photos.app.goo.gl/TJSwgsm4nqQgh3Y2A
Again, I should have moved on much sooner, but I am losing my mind about the way they just ignore my answers. I realize that the outcome will likely be that they want me to return them (which is expensive, and will take forever), but it is just not about that anymore! I am having a hard time just bending over
