Slowroller
- Granite
Not sure what could have caused this... My Granite BLX running a 3S battery began making a noise and not moving. Upon inspection the slipper gear was toast ground down smooth. Looking closer and removing the power module I discovered the case for the slipper had a small crack, the red motor mount was bent causing the pinion gear to be pitched and the shaft for the slipper set was also bent. A lot of damage and not sure how it happened. The Granite is new with only 3-4 runs without any major crash resulting in damage. Any thoughts?
