Would a 35kg work well in a blx? And would I still need to get a 25t servo saverYou don’t need an expensive servo like the Reefs: the Amazon Annimos 25kg servos are inexpensive yet powerful and reliable. If you are going to upgrade your servo I wouldn’t suggest a servo with less than 25kg of torque. If you want something a bit better than the Annimos servo I suggest a Power HD 25kg servo. I’m running a 25kg Power HD servo in my Typhon 3S.
The ARRMA 25T servo savers are on back order, but you can get either a Kimbrough 123 or Kimbrough 124 25T servo saver to use with your vehicle. The 123 has slightly less spring tension than the 124, but unlike the 124 the 123 doesn’t require modification to work in an ARRMA 3S. I have a 123 in my Typhon 3S.
You will need a new servo saver: the stock Spektrum servos are all 23T, and most any other brand of servo is a 25T .Would a 35kg work well in a blx? And would I still need to get a 25t servo saver
I run an amazon 35kg in my senton/granite. Works great, and cheap enough to order two and have a spare on hand. I believe im using a kimbrough 123 saverWould a 35kg work well in a blx? And would I still need to get a 25t servo saver
