Tried little bearing ball under grub screw, then a big drop of blue loctite..ran limitless 100+mph , until 6s was done, it held..thank for the tip..herd of doing this before at kart track..but forgot..lol..Use a little red just heat it up to remove.
Another option is disassembling a old bearing and using a single ball under the grub
Did you let it cure for 24hrs before giving it the hamm?!..put big drop of biue loctite on pinion gear grub screw. On limitless, running 6s, not holding.. anyone else have same issue ??.. afraid to use red..any suggestions ??
Shure did plus some,more like 3 days before had time to mess with it again..then there is the Michigan weather..rain,rain..Guess know about weather being..in minnosota..lol..Did you let it cure for 24hrs before giving it the hamm?!
