DJ40andOver
- Outcast 6s
- Senton 6s
So I got an Outcast 6S for Xmas. I've had it out 4 or 5 times & the first upgrade was replacing the stock Transmitter with an Spektrum DX5C. When I took the receiver box cover off, I noticed that the white wire, coming from the ESC was frayed because it was not in that little notch in the corner like the other wires. That was about a week & a half ago, & i have been messing around with different Spektrum receivers. Yesterday the worst happened, & the wire basically just came apart. I stripped a little bit back & wire-tied it, which worked intermittently when the receiver was out of the box. However whenever I tried to put it back in & screw the cover down, it would not work. I took the fan off of the ESC in hopes that I could replace all 3 wires as one unit but it appears to be hardwired into the ESC itself. Is this something that could be repaired or am I stuck with buying a brand new ESC?
edit: So I did some looking around. If this can't be fixed, what do you guys think about the Spektrum Firma 150 as a replacement?
