Idk what he did.https://www.arrmaforum.com/threads/arrma-granite-4x4-6s-blx.5556/
You were in his thread and you see how he solved that problem
He explains the steps needed in the second post linked above.Idk what he did.
Which part are you calling the 'slipper hub'?For the people that run 6s in their mega, are you guys breaking slipper hubs? I put a 6s in mine and broke a slipper hub instantly.
Yes I did but this is what im breaking.Which part are you calling the 'slipper hub'?
You already did the HD diff input mod, right?
This is what im breaking.
It is breaking where it connects to the input gear and 4s is not fast enough. It feels slow for 4s.Where is it breaking? At the pin? or is the disk breaking?
The solution may be to back off the slipper pressure. It will be a balance between enough slip to save broken parts, and tight enough to not melt everything in a few seconds.
Edit - Oh, and after my last 4s run, I know I will never go for more power. Plenty of power for me on 4s.
