Country Boy
I have a hobbywing programm card and wondered if it can be used with the blx 100 esc? If it can does anyone know which hobbywing esc it is comparable with?
The led segment display type card works. The lcd display type card does not.I have a hobbywing programm card and wondered if it can be used with the blx 100 esc? If it can does anyone know which hobbywing esc it is comparable with?
Matches my experienceThe led segment display type card works. The lcd display type card does not.
This type
Not this type
Its the top one I've gotThe led segment display type card works. The lcd display type card does not.
This type
Not this type
Bear in mind the programming numbers don't correspond to the ones written on the box. You will need to google search for the corresponding programming numbers for your esc.Its the top one I've got
The correct programming item numbers and values are contained in a chart under ESC Tuning Options on page 16 of the 4x4 3S Get Started! manualBear in mind the programming numbers don't correspond to the ones written on the box. You will need to google search for the corresponding programming numbers for your esc.
