RJUK
- Thread starter
- #21
Amazing, thanks for taking the time to explain this. I'm currently considering the Keaton EXB or the Mojave EXB. Here in the UK I can get the Kraton EXB for GBP 429.00 and the Mojave EXB for GBP 574.99, so the Mojave is basically £135.00 more. Is that just because the chassis is bigger, or does the Mojave have upgraded stuff that the Kraton does not?The drama was that the Kraton EXB had a quality control issue with the build being the first release post COVID with a new differential design. They fixed it with a spacer that prevents the issue and the new EXBs have this resolved. They waited to release the Mojave EXB until they had the differential issue resolved which has been done. The Mojave EXB comes with the upgraded diffs and are a nice improvement over the previous versions. Great truck, very tough and no concerns. If you want to avoid drama and keep it basically stock just order the electronics that come with the RTR version or choose from a reasonable setup from this forum that will fit the stock motor mounts and such.
Most people having problems have put much larger motors that stock and geared higher as well.
I’d advise you to take RATT’s advice with a fistful of salt. You don’t rip an Outcast 8S in half without a major crash with serious forces.
Personally I really enjoy my Notorious 6S. If you like the look of the Mojave EXB I think it is an excellent rig.
I like the look of the Mojave a lot, especially the EXB version, but it's another SCT, so I guess will still be more likely to roll over than the Kraton due to being narrower and taller, and will have the same issues with muck going into the body/chassis like my Senton. So it gets me wondering if the Kraton would be a better idea.
Do the latest EXB Kratons have the same diffs as the Mojave then? And is it 2x LSDs?
Thanks.
