OK looking at them I've seen 3 utube vids stating that they aren't the best. I'd just go dog bones mate
There are no specific CVD's for the Typhon 3s. Option parts for the Typhon 3s list the same CVD's as the Granite and Senton 3s.Did you buy the specific cvds for the Typhon they have longer arms?
Do the 4s 17mm hex CVD's fit a 3s Typhon?It is the wrong pic, basically it must be the same CVDs as for the Kraton/Outcast 4S with the 17mm hex.
Yes you can, Integy makes them. I run the Arrma CVD’s on 4s. I’ve broken the CVD’s, but I was shredding the stock shafts. Also they make a longer set for the 4s models, that’s probably what you want!You can't get dog bones for the 3s cars?
Too bad, I've started to pop driveshafts jumping off a new ramp. The Granite CVD's are no good because they use those flimsy axles which I was snapping even with a smaller ramp.Nothing I tried worked with other CVDs, so simply ignore my posts
Pics please. I’m not following what you’re saying. The arms of the 4S at the ends are different spacing than the 3S. The hubs and caster blocks are wider on the 4S. The bearings are larger in the hubs as well. There aren’t many shared parts.@jondilly1974: when replacing the axle hubs as well, it would work as the 4S ones are mounted outside and the 3S ones are mounted inside. But required also to replace some other parts. Thats what I've tested today. But then you can also buy the tuning CVDs. Same or even cheaper price and less effort.
The 3s and 4s Arrma CVD’s are identical, 4s is longer. You can interchange the ends.Granite and Typhon both use the same stock driveshafts. However, aftermarket solutions might not have enough slide for the wide arms of the Typhon. The 4S rigs use completely different hubs and bearings and cannot be mixed with the 3S parts. They really only share a chassis. Everything else outside the chassis is unique.
Ok I get that part. The stock driveshafts on the 4S are larger but the CVD middle section can be used for both, is that the point? Good info. ??The 3s and 4s Arrma CVD’s are identical, 4s is longer. You can interchange the ends. View attachment 105781View attachment 105782
