Nope. Even though it's a Hobbywing knock off, no program cards work with it. You'll have to download an older 6s manual to get all the options and how to go about changing settingsHi I’m having a problem setting up a BLX 185 esc.
My question is, is there a program card for the Arrma BLX esc’s. So far all the ones I have tried I’ve had no luck with.
Okay, I'm wrong then. Hadn't ever found one that did, but never tried the Spektrum. + 1 for you brotherSpektrum makes one that works. It’s an LCD version vice the LED versions that Hobbywing makes. I have one: it was the only card that worked out of four other cards I had.
Have you got a picture of it so I can try to track one down please budSpektrum makes one that works. It’s an LCD version vice the LED versions that Hobbywing makes. I have one: it was the only card that worked out of four other cards I had.
This one works with both my BLX and Firma ESCs.Both the Hobby LED and LCD program cards work with the BLX escs, they do not work with the Spektrum Firma escs, at least I couldn't get either of my program cards to work with my Firma esc.
LCD https://www.hobbywingdirect.com/products/lcd-program
LED https://www.hobbywingdirect.com/products/led-pc2c
But you have to follow the program chart in the manual not the one on the card.
All 3 of mine won’t work. I’ve plugged them all in to the fanand nothing they light up but that’s it.Both the Hobby LED and LCD program cards work with the BLX escs, they do not work with the Spektrum Firma escs, at least I couldn't get either of my program cards to work with my Firma esc.
All 3 of your what wont work with what?All 3 of mine won’t work. I’ve plugged them all in to the fanand nothing they light up but that’s it.
I have a led Hobbywing a lcd Hobbywing and the lcd Spektrum. Silly question but do you have to plug them in and press the esc program button. All mine light up but that’s it.they work on my Hobbywing and Spektrum.All 3 of your what wont work with what?
I have 4 BLX escs, 2 185s and 2 100s, they all work with the Hobbywing program cards.
I have both the LED and LCD program cards.I have a led Hobbywing a lcd Hobbywing and the lcd Spektrum. Silly question but do you have to plug them in and press the esc program button. All mine light up but that’s it.they work on my Hobbywing and Spektrum.
Have you got a picture of your program card?
Same one as mine but all I get is a - across the ledsI lied the LCD box does work with the BLX escs. I could have swore I used it to program the one in my Summit.
But here is the LED card.
+!All 3 of your what wont work with what?
Well I finally managed to do it using the Hobbywing led card! Thank god.Question from the back...have you tried entering programming mode using the transmitter? You know, just to verify that the ESC is functioning as it should? Of the three cards at least one of them must work, statistically speaking. I just figured it might be worth testing if the ESC is ok and will respond to a different sort of input or if it just lights up and does nothing. Can't hurt, roight?
It's always the little things that get us, innit? Except when it's one of the large things. But that's just common sense really.Well I finally managed to do it using the Hobbywing led card! Thank god.
It turns out I had to do the throttle calibration first, after that the program card started playing ball!![]()
+1Question from the back...have you tried entering programming mode using the transmitter? You know, just to verify that the ESC is functioning as it should? Of the three cards at least one of them must work, statistically speaking. I just figured it might be worth testing if the ESC is ok and will respond to a different sort of input or if it just lights up and does nothing. Can't hurt, roight?
