- Location
- Illinois
- Fireteam
- Infraction
- Limitless
- Kraton EXB
- Talion
- Typhon 6s
- Typhon TLR
Does a gyro behave differently based on location?
Front, middle, rear, etc.
I may not be the best at answering this question since I have only dealt with Spektrum AVC gyros. No, I have not found those to matter based on the location of the rig. For Spektrum, need to pick a side on how it will sit and calibrate AVC correctly. Front, middle of the rig I have not found a difference.Does a gyro behave differently based on location?
Yes, Absolutely. If you leave a gyro laying in your dresser drawer or in the bottom of a fish tank, it won't perform at all. Location is crucial!Does a gyro behave differently based on location?
I don't have anything objective to back this up with, but my instinct is to put it towards the center of the vehicle since that's middle of the axis of rotation that you're trying to correct. They work at the front and back as well but I've not done any testing to try and determine whether it reacts differently or is more sensitive in one position or the other.Does a gyro behave differently based on location?
I use the predecessor, the GYC441 and, while the manual doesn't explicitly make any recommendations about the position, I think this illustration helps to visualize the rotational axis I was referring to. If you imagine the gyro, just as an example, being over the front diff/axles, the gyro will be experiencing more of a side-to-side acceleration rather than rotational forces. As I said, I haven't done a comparative test between the two positions but I'll take your word for it that it has an effect on how the gyro operates because it matches up with how I think they function (confirmation bias: ENGAGED!).To piggyback on this. I agree with @Diem Turner in that it operates best from the center. Too forward affects the way the gyro corrects the steering.. it still works but not the best that it can.
I use a Futaba GYC470 and there’s a noticeable difference in stability between to forward and center.
However, if a bashing car I’d say put where it’s most convenient and protected because you’ll still benefit from having something versus nothing
Gyroscopes were designed to sense rotational deflection (which was the central idea of my hypothesis that a central location should result in better sensitivity than somewhere at the front or rear of the car) but they also generally sense changes in orientation.I always thought near the back axle was best because that's the location that would most likely kick out. So I'm theory it would pick up the movement first and have more time to correct. But also agree with some others that at the center you get more rotation of the gyro than side to side movement. Guess the real question is if your gyro reacts to side to side movement or rotational movement more.
A gyro positioned in the central red/yellow circle should experience every little deviation from the direction it's travelling in quickly. If positioned in the nose where the blue/orange circle is, as the car breaks traction, due to the larger arc because of its distance from the center will first experience lateral acceleration before it begins to rotate. It's possible that this works just as well but, in my imagination anyways, the central position fits more into the natural axis of detection and the front position might be better served by the addition of accelerometers. But I'm just flapping my chocolate starfish, I don't have a comprehensive understanding of they sense movement best.
Hot dog flavored water is also required I do believe!You had me at chocolate starfish
Most of mine are either mounted in the recievers box, so near middle ish but off to one side. Or under the "canopy" area of my buggies, (because that's where there's space) which is just rear of the center position. Now that you got my mind going I'm going to have to test out one of my cars by shaking it left to right, then rotating it. Will see if there's a noticable difference.Gyroscopes were designed to sense rotational deflection (which was the central idea of my hypothesis that a central location should result in better sensitivity than somewhere at the front or rear of the car) but they also generally sense changes in orientation.
I don't really like it for bashing. I might keep it on low if I'm just blasting along rough terrain to help it hold straight, but if I'm jumping it's gotta be turned off. Always seems very unpredictable when doing jumps and flips with it on.For bashing, why would you need a gyro to begin with, but many uses it to get heading hold but won't do anything else despite the fabled claims. Us older folks rip it out and use the trim knob to make it go straight.
Great video. Thanks.Saw some interesting results in this gyro position test. Not sure if this applies across the board of different gyro manufacturers so I'm still going to test out my dumbo gyros to be sure.
Awesome, this completely and utterly demolishes my preconceived notions and hypothesis. I could not have been more wrong. Anyone who reads through this thread, disregard anything I wrote. Thanks for the video Mike, much appreciated.Saw some interesting results in this gyro position test. Not sure if this applies across the board of different gyro manufacturers so I'm still going to test out my dumbo gyros to be sure.
Don't doubt yourself yet. I still think it's possible different gyro may react different.Awesome, this completely and utterly demolishes my preconceived notions and hypothesis. I could not have been more wrong. Anyone who reads through this thread, disregard anything I wrote. Thanks for the video Mike, much appreciated.
