Vendetta EVERYONE,LETS BUILD A 145/4S VENDETTA
I'll be tuning car with old beat up body..haven't bought 1 yet ,but will get new 1 soon an go throu what I do to them
Bro you said a couple weeks.. wtf, see.. glad I jumped the gun, still fell behind!! šŸ˜”
I'll be running 2s for a whilešŸ˜…šŸ˜‚šŸ¤£
@K-BASH the lines on the tires is brilliant my friend I'm gonna use that
White chalk marker works best..I go for equal wear on both tires.the ones been wore off making harder to see,but works great
Front tires
Settings an log...I'll be installing perfect pass so I can do somewhat equal hits to see if it shows on logs as I free drivetrain(resistance) out of car...after run I immediately went over car with temp gun..none moving parts 64...rear diff was 68 at axles...front diff was 73 at axles..so I've got friction in front,(resistance)..front should never be hotter than rear on this car.rear does most the work..
These 4 screws are flush from the factory. I always start with all diff screws loose,few runs into car,then tighten some..run car few packs,then loosen them run car,repeat till everything is loosely smooth with little resistance.i run them for pbz loose also..do all my cars this way..once I get PP logs we will start pulling resistance out of it an see changes on logs
I do not want to be that guy, but I am going to prove that this will not work most of the time.
This will only work on a set of new tires.
This is a great temp fix but you would have to readjust every few runs if you did not start with a new set of tires since you would have a high spot on the tires then when you adjust it would where down and them you would have to readjust, you would be bouncing from - camber to + back to - I think the best way is to use an Angle Finder (though have not found/used this 1st hand but I do own one and will start using it soon and this is the way McCoy sets his cars up and you know that what McCoy says are own Liberty takes as gospel of RC speed :LOL:). This trick (chalk) would however work on a new set of tires since they are the same (mostly) on the inside outside and in the middle.
Tell me if/where the flaw is in my statement.
TN-RC
