- UK
- Felony
- Mojave EXB
- Notorious
- Outcast 6s
- Typhon 3s
I don't have the gears in person so please correct me if this is incorrect, but I really don't think shimming up these gears is going to help!
As @jym73 said, the shims sit on the inner diameter of the gear, which isn't even a flush surface. Shims are circular in shape, yet this gear is shaped as a cross where it comes in contact with the shims. Under torque, the gear will twist at an angle because the gear has no support on it's outer diameter, which will result in a poor mesh and cause it to chip. This is surely a design flaw ??
In reality what is needed is a flush gear of which shims will fully contact the gear's flat surface area. Or just add the LS plates to pack up the area it leaves when left out and have an LSD in the rear instead
Image courtesy of @Cirasa
