Lucky me who wanted to seal my hardcase lipo because it was flooping all round the case inside and saw how trashy the case was made i was able to compress both halves of the case and hit the lipo the top has a small double sided tape with foam and ag the bottom nothing and there was a small rock who almost punctured a hole ?
A receipt for disaster a little rock gets inside the lipo u land a high jump and boom disasters i think i saved mine in time will seal the wires with shoe goe
sadly every hardcase lipo i had all of them had this kind of damage inside the hardcase
I will ask for a refund of the second lipo its just disapointing to see. Its like lipo manufacturers don't know what they are selling and where those lipos are going to be used
So far my hrb 4s soft case has been the best lipoi ever bought 5000mah+ everytime i charge it from fully discharged and claims to be a 5000mah lipo while the other the awanfi gets 3500mah(5000mah rated) 4600mah for the zee (5200mah rated) the awanfi only had 3 cycles so they might increase in capacity like the zee did.
Are hardcases better than softcase? Depends if your lipo get ejected they will be saved but stuff getting inside your lipo and damages the protective layer ruins the purpose of having a hard case lipo makes it somewhat more dengerous when you specially want it to avoid damages by rocks or other hard stuff when running your rc and they charge you like 10$ more for an hardcase option
Issue could be easily fixed by covering the top and bottom cells with equal sized foam tape
its my take on it?? I think im going to just support hrb and get soft cases and protect them with gorilla tape and shoegoe for the seal
