Kraton How do I remove a stuck motor bearing?
Solutions
Oregon
My Kratons motor bearing exploded and now is stuck and I tried the bread trick and it literary bent the cap where the bread was so I Viced it back into shape any ideas on how to get it unstuck or I’m stuck with buying myself a motor for my own birthday image.jpg
Hammer Down
It’s only money... you’ll make more tomorrow. 😎
Solutions
1
The coldest place on earth!! (Minnesota)
  1. Infraction
  2. Limitless
  3. Kraton 8S
  4. Kraton 6s
  5. Outcast 8s
  6. Outcast 6s
Nobody has a toasted motor they can send the kid an end cap??
@jondilly1974 you are the motor slayer after all... no end caps?
I’ll send him a working motor if nobody else has just a cap...
Solution
Unsprung1
Torching it for a SHORT ! Time, then drop an ice cube, or Popcycle if you’ve got one on the bearing only, not on the plate, , should pop right out. I always carry dry ice & a torch into the mountains when crawling my 1/1 Jeep with 38” tires. Even if I don’t break, many others do gotta help each other! Heat is always the enemy…
