- Thread starter
- #61
wondering why the 4070? They are the long type correct? I am thinking about getting the smaller one so i can keep stock orientation and i will put custom battery mounting in.If this if your first time trying to go over 120mph I would stick with either a TP4070cm or 4080cm.
Then look to upgrade to a dual motors setup later. Most all of James McCoys setups are running these 2 motors. In fact almost all the guys up around 200 mph are running these 2 motors.
With a simple TP4070cm I hit 135 mph on just 3 cells in a 1/7 scale car.
You will need to learn about the car and data logging if you want to run high speeds. Many of us found running low cell 2s-4s helps you learn a lot about setups and understanding the data.
If the car was going 120 mph with a 12s setup and tried to go the same speed on a 8s setup, then yes the amperage would go up.
The problem is that in the end wattage is what matters.
I am going to use 3.375 volts per cell under a heavy load as the example here. This means top tier lipos and a very good throttle application with the correct gearing.
HW 12s setup
12s = 40.5v
40.5v * 250a = 10,125 watts
XLX2 8s setup
8s = 27v
27v * 600a = 16,200 watts
We have seen the XLX2 go beyond 600a but just using this as an example.
This is a XLX2 log running 3s in the 130+ mph speed range. Notice the amperage
