SpadedJuggla
Just bought a V2 Infraction and the hand brake servo gears or the servo arm has stripped already and I am wondering if there are viable replacements to both parts that are metal so this does not happen again.
Bought it at a local hobby store and i am sure they will help with that but I am looking for an upgraded one to prevent it from happening again preferably to metal gears as well as a metal arm that attaches to the servo itself. That is if they actually exist lol.Welcome! You can get a warranty replacement from Horizon but the handbrake servo really needs to have its travel limits adjusted. It’s pretty easy to do on my DX5 although I’m not sure if it’s possible to on the stock DX3 radio.
S650 has metal gears. Poor endpoint setting out the box ruined that arm/spline and stripped it out. IMHO. The adjustment arm at the module also needs some adjusting too.Bought it at a local hobby store and i am sure they will help with that but I am looking for an upgraded one to prevent it from happening again preferably to metal gears as well as a metal arm that attaches to the servo itself. That is if they actually exist lol.
I pulled it apart earlier and it all looked plastic to me. The servo had white gears and looked plastic and the arm is def plastic. I'm all for other upgrades but I do want to change the red bits out like the hubs and mounts to blue ones but have yet to find a site or place that sells them. Tomorrow I will get pictures of the servo and post it here to show that on mine at least it is plastic gearing.S650 has metal gears. Poor endpoint setting out the box ruined that arm/spline and stripped it out. IMHO. The adjustment arm at the module also needs some adjusting too.
Did you see my earlier post about the alloy upgrade HB module.?
But I would just remove it altogether. Its not all that, to have or use.
My V1 Infraction is fine without the novelty of a HB.
What is the purpose of it in reality? Save money for other upgrades. Your call.
It crapped out and will do it again. Especially if you are not using it per the manual. And the manual tells you to use it in a way that is not really practical. HB only when trigger is in neutral or you risk damage. Kind of awkward using the Tx like this, if you ask me. What's wrong using just the ESC brake?
Just me.
Just me.
so my question is are either of those plug and play for the hb?Correct, S650 runs nylon gears. S651 has brass gears and S652 has steel gears
oh excellent! Thank you good sir. I can now get a replacement servo ordered and really get it set up so i don't have to replace such a minuscule part again lmaoBoth are. Both are 23T and will slap right in.
This is the video for setting up the end points on the servo. Infraction comes set as 3 position (B activates the brake and A pulls the brake further away) for some stupid reason. I would just set it up in 2 position in my opinion.
Hi, how do I adjust the end points, I get how to do in on the transmitter but idk like how much travel I should give it, like what pointers should I follow so it still grips tight but not strip the servo. ThanksAt most I would go up to an S651 or similar lower powered servo. Definitely adjust the end points, it's easy as pie with the DX3. You won't find any arm better than what's already on there imo
