- Thread starter
- #101
Yup. Glad the BLX4s gear is coming out soon. That, and I have some spares on the shelf to get it going in the mean time.
I guess my idea of dropping the motor pinion tooth count to lower tire speed was not a great idea.
This was on 3S, 2S or what?I was running it for a while with a 17t pinion, and had no issues
Can Diameter: 46.35mm (1.8")probably a safe assumption, but I have no idea how big those motors are. the 40mm can of the BLX185 fits.
I just pulled those measurements off Google, that includes the torque ring, without the torque ring it is 42mm.46mm diameter is pretty big. I'll need to double check how much clearance the 40mm motor has, but I'd guess that I don't have 3mm extra.
My advice? You are not comfortable, only because you don't do it. So go do it, and gain confidence. (Yeah, my kids probably kind of hate me LOL)
But seriously. If you don't want to try it right away, then just buy some spare diff inputs, set the punch low on the ESC, set the slipper right, and hopefully you won't break them every other run. Plus after you have a broke one, there is no harm trying to drill on a junk part, right? Can't screw up something that is already junk. Part of the beauty of this conversion is you can do it to the broke part - no need to ruin a good input. And if you get it done right, then no worries about breaking the new plastic part first run.
For the pin, a Dremel with a abrasive cut off wheel will make short work of it. It was only tough for me because my Dremel died and I have not replaced it, so I was trying to use a hacksaw blade in a saws-all - Classic wrong tool for the job issue.
The HD input is really a pretty easy job. But it is something you can put off till you break a few of the plastic inputs, if you don't mind fixing the truck.
As far as the factory HD part - it was originally listed back in January / Febuary, with a Mid-May delivery. And still no sign of it. IMHO, I think the double hit of the Hobbico bankruptcy first stalled it, and now the (hopefully) looming BLX4s release has it delayed more. (The BLX4s takes this part to 100% metal, instead of metal shaft, plastic gear) The Tower leak showed the BLX4s release to be Mid July, so hopefully soon.
Noob question. What is BLX4? Are they going to make a brushless version of the Granite 4x4?
Yeah possibly.I forgot to look at the truck last night, sorry.
You planning on building up a brushed Mega?
