chrisexv6
You put a shim(s) OUTSIDE the bearing. Cram as many as you can and still have a tiny bit of backlash on the input pinion. Just like when you set your motor pinion mesh, you want just a tiny bit of play. The smallest amount you can get before there isn’t any play.
I was referring to this way of doing it, but the result is probably the same result both ways:
