Kraton k6exb 'beefcake'
dqb
Texas
  1. Kraton EXB
  2. Vorteks
First off, a big thank you to everyone on the form for sharing such great information and the mod's for maintaining a wealth of info - as a new builder I was able to get through entire build without having to ask any questions.
6sEXB / Castle 1717 1650kv / MMX8S / M2C / PPS / JBI / ALZA / GCRC
TLDR Pic:
The build in chronological order:
Planning
Phase 1 start
Roller arrived on mother's day, thanks FedEx :rolleyes:
Parts laid out for assembly
Was too excited to get started and forgot to take a 'before' pic
Fully broken down
PPS motor mount 🤤
Reassembly
Phase 1 complete!
After several packs I identified the following items to correct in Phase 2:
1. My makeshift servo mount extension was twisting / not going to work long-term
2. Motor was quickly getting to ~165 temps even with 18/50 gearing and would need fans
3. Tires were good but not great
4. MMX8S fan already broke
5. Spektrum tx/receiver felt slow and was a pain to switch between cars (with and without gyro)
6. Lots of un-necessary wiring
Phase 2:
JBI mount was a pain to get in; even after prying it into place I found the stock screws were ~2mm too long and need to file them down as I didn't have any of correct size:
I went with with K8 heat sink with some .5mm thermal pad to make the connection
GCRC 'Maximus' (50mm) motor fan would not fit so cut the body for a cold-air-intake kind of thing
GCRC 'Typhoon' ESC fan required different screws than the MMX8S so used an M3 tap to get it together
Able to stuff Flysky FGr4 and castle bluetooth in the stock box.. barely
Phase 2 result:
Phase 3 will be mostly cosmetic/reliability and will begin when I have a significant breakage (already stockpiling parts 😏).
Overall very pleased with the build, averaging ~130 temps in 90+ ambient on 20/50 gearing and handles great. Full weight comes in at 15.4lbs. Only regret was not including ceramic bearings in phase 1; now am faced with the daunting task of tearing everything apart to mark project 'done'. Only other regret was not building sooner.
And for those interested here's my gearing on 6s with backflips. I haven't GPS'd it yet and I don't really care to, but I think the 46mph calculation below is very conservative.
TLDR Pic:
Planning
Phase 1 start
Fully broken down
PPS motor mount 🤤
Reassembly
View attachment 220648Phase 1 complete!
Phase 2:
Phase 2 result:
Congrats! That's very cool!
Solid looking build man. 👍
Love your eye for organization, especially for screws placement -that outline of the chassis, smart!
And, Welcome to the Ranch!
I'd imagine that castle combo doing more than 46 with 20/50
I believe it does. Take calculation with a grain of salt as I hacked to simulate real world; decreased lipo cells from 6 to 4, V/cell to 3.75, and did not account for tire balloon. When I get bored with it I’ll test ~24/46 but for the time being it’s an absolute riot to drive and has not left me wanting ‘more’ in any situation I’ve put it in.
Build Update: Long day at the workbench yesterday but rebuilt all three diffs adding M2C Outdrives, replaced all bearings with Avid ceramics, and swapped in M2C extended 17mm hex. I also tried to install RPM wing mount but couldn’t get it to fit, but I may have just been delirious as it was after 2am by that point.
Happy that I serviced as soon as car started acting funny, found that rear diff had no gasket from factory and was not surprisingly bone dry.
Went with 50k front, 200k center, 20k rear, and left the LSD in the stock configuration (min effect rear, max effect center and front) but would love feedback on this as I couldn’t find much intel or compelling arguments on ‘effect’ vs oil weight.
Also worth noting, I used these for the first time and they worked out great:
_degreasing wipes - useful for cleaning old grease off of diff and scooping out of bulkhead
_foam swabs - shred resistant and small enough to ’screw’ into M2 threads with break cleaner. Got awesome contact this way and will def use these for everything on the go forward.
Update: received skyrc gps today and took it out for a quick spin. Drove on sketch road (smooth & plenty straight but no curbs and lots of lamp posts) Below is pretty close to top speed but think it may have a little more to give.
Obvi a significant delta from my original calculation:
Haha that's funny, I knew that site was accurate. I put in your info and got this.
Wow that apparently is more accurate. I like being able to save profiles so I just changed the LiPo cells and voltage to get the top speed to match in my app.
One unanticipated benefit of rebuilding diffs and adding ceramic bearings is that motor is running cooler; after those 4x speed passes and some light grass bashing my motor temp was ~20deg cooler than it normal. I’m going to step up from 20T to 22T tonight to and will compare calculations vs gps again to see if calculations are dialed.
’m going to step up from 20T to 22T tonight to and will compare calculations vs gps again to see if calculations are dialed.Up
Change of gameplan; against better judgement I ordered aluminum bulkheads and F/R hubs.. going to get new weight before regearing.
Cleaned all my old bearings today, oddly satisfying process.. maybe because it brought me back to my old skateboarding days. Big win was finally getting my 5yo involved in an ‘assembly line’ process!
TLDR Pic:
Planning
Phase 1 start
Fully broken down
PPS motor mount 🤤
Reassembly
Phase 2:
Phase 2 result:
What did you use to get these figures ?
What did you use to get these stats ?
