Hi all thought I would share my latest build a scx24 deadbolt nicknamed the "hulk" that now has about $500 in upgrades that include.
Upgraded to v2 electronics.
Injora 66t 050 motor.
Emax servo.
Injora brass beadlocks.
68x25mm tires.
Treal 43mm double barrel shocks running no springs.
Treal high clearance gladiator links for longer wheelbase.
Treal 4 link conversion.
Treal steering links.
Treal servo horn.
Treal brass servo mount.
Treal brass knuckles.
Aluminum axle tubes.
Brass front diff cover.
6mm extended axles.
6mm 15g extended wheel hex.
Injora stainless driveshafts.
Injora underdrive gears in rear.
Injora overdrive gears in front.
And can't forget the rubber band limit strap on front axle lol.
And I'm sure more to come.
Total weight right now is 558.5g
Emax servo.
68x25mm tires.
Treal servo horn.
6mm extended axles.
