- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
- Thread starter
- #161
Hopefully this isn't one of those moments when you learn how the magic trick is done and now its not special anymore!?
I decided I would rather encourage people to build things, than hide secret methods of how things are done. Soooo without further adue the front steering setup is Arrma 6s using the rear Arrma 6s axle stubs to allow input of a dog bone instead of CVD.
The Arrma 6s front knuckle/hub screws directly into the aluminum part instead of an upper and lower A-Arm.
Thanks to @Mr.Duke for a great write up on pressing in dog bone pins.
His thread on this is: https://www.arrmaforum.com/threads/replacing-driveshaft-dog-bone-pins-on-arrma-6s-vehicles.14362/
His link for the tool was no longer good, but I found it here:
https://www.snowguarddepot.com/products/s-5-s-5-e
The tool is on the way and should be in this week. At that point I can make the front axle. Basically it is a 8mm shaft with pins on either end to function like a rear dog bone would. I'll have to assemble everything and install one of the pins after everything goes in as they wont pass through the bearing.... Not the most ideal setup for servicing, but it is what I came up with. I'd love to make the front a CVD setup one day, but for now a more simple approach was best.
