HoleyDonut
We've only run it on short grass around the park and on the sand found in and around the playground. The sand on the pavement made for some great drifting...while it lasted. We are running the unit completely stock...I don't know enough about these things to even start about making modifications. Like I said, it took us two hours to change just a motor out...because we don't know anything about these things. It's just been humbling start to this hobby.If your running in grass it may be putting too much stress on the motor and esc. None of them like running in grass Including the 3sBLX and 6s line. very short grass, dirt, and pavement are best. If you are running in medium grass you will need to go smaller on the pinion.
Yes, I have heard about that. Like I said in my original post, it took two hours for us to change just the motor out for the second unit which lasted three runs before burning out. We are far too new to even begin thinking about modifications...and no one at the store seemed to be willing to give us a hand with the motor changes either. Everything is stock. By running it at 50% of max, we assumed it would also last a heckuva lot longer than three days when the first motor burned out. Two days of downtime later, had the second motor in and that burned out a day and a half later.You can get a brushless motor and ESC for less than $100 that with last a much longer time than the stock brushed motor and esc.
Does running the unit at 50% or even 75% kill motors faster than at full tilt? We wanted to keep the unit slower so my kid could keep up with it, at least until he could control it better. Seems reasonable, right? He's eight years old.
So the first week of ownership:
Lots of downtime trying to figure everything out, reading instructions, manuals, learning to charge the battery properly. This all resulted in two blown motors. Two 2-hour drives to the store. ...all for a grand total of seven runs, two of which ended in blown motors...and none of those seven runs lasted more than 15 minutes.
