- Limitless
- Nero
- Talion
I think I figured out lipo C-rating. Most batteries charge at 1C. If the battery is 5000mah a safe charge rate is 5A. You can charge batteries can charge above 1C, but if you do, it will reduce life of the battery and increase likelihood of fires. If you have a battery that has a discharge rate of 50C (same unit) it means the amps draw limit is 50*mah. Many members of this forum say discharge C-rating doesn't mean anything. I think they are wrong. If you "can" charge about recommended limit for the battery, you increase likelihood of problems.
If I am correct, it is the same with discharge rates. You can discharge about 50c, but if you do, you will increase damage to the battery. If you do it enough
Do you think I am correct?
