- WIS.
- 4x4-Mega
- Kraton 8S
- Kraton 6s
- Senton 6s
- Senton 3s
Well i hope gps ones work better for you because they didnt last one full run for me
And regarding backflips and air control, I found the tires the most interesting marker. Got lockups and sixpacks on the oc8s, it flips like the 4s outcast with the above setup, 780kv/max5!Same with me mate, 39/39, max5 56112 780kv rocket /surpass, double backflips,80 ft launches, no standing backflips, punch 5, 120c 7200mahs , only broke a pvc stock rod end today, still stock 5mm shafts in the oc8s. I've got thick gps haven't had to install yet, heard bad things about them, no?
The heavier the tire, the easier the flip, no news I guess.
But honestly I can now do a double flip in a 10m jump, wasn't at all possible with the dboots.
Also the grip of the lockups and hatchetts is amazing.
I've had only a few runs though with mostly limited throttle.
Keen to hear a lifetime solution from the racing engineer;-)
Yep... im sure I'll join the club sooner or later...Well i hope gps ones work better for you because they didnt last one full run for me
On another note, has anyone got a bulletproof shock solution for oc8s or k8s exb? Still think the rovans 190mm from 5t/baja might be good, especially if you cut a thread into the end of the 8mm shaft directly and put a nice metal female 8mm rod end on?And regarding backflips and air control, I found the tires the most interesting marker. Got lockups and sixpacks on the oc8s, it flips like the 4s outcast with the above setup, 780kv/max5!
So to bring this all back on topic... Took the new motor out today. Just got started and guess what ended my fun? 3rd M2C driveshaft failed on me. But I do like the 1100kv better than the 800kv so far. Feels more responsive. Running 29/39 gearing right now. None of my concerns with it not having enough torque like the HW 1100. Entirely different beast.This deal is legit. Showed up today. Loctite is drying. Hope to run it tomorrow.
Wow. That is an amazing price. Yeah, it's from Amazon, so it shouldn't be a problemWell needed a new esc for my infraction so went for it. Really hope I didn't just get ripped off. This price seems too good:
https://www.amazon.com/gp/product/B08MGXZPCQ/ref=ox_sc_act_title_1?smid=A2O50O9WC1KTI1&psc=1
I played around with the gearing and 800kv motor. I was never happy with it personally. I'm happy with the 1100kv motor.Yeah, same watt output from the 1100kv vs 800kv castle 2028 cans. Performance and responsiveness will change with gearing and ESC settings. You can make an 800kv 2028 respond the pretty much the exact same as an 1100kv 2028 by tweaking those two main things.
Wow. I saw someone break one of the M2C driveshafts but he was running in a very extreme surface (construction zone I believe).I run my rigs at the park with dirt/grass.So to bring this all back on topic... Took the new motor out today. Just got started and guess what ended my fun? 3rd M2C driveshaft failed on me. But I do like the 1100kv better than the 800kv so far. Feels more responsive. Running 29/39 gearing right now. None of my concerns with it not having enough torque like the HW 1100. Entirely different beast.
I gave my M2C driveshafts hell with the Outcast 8s yesterday. I did everything that I could to break them (I just needed to take out the kitchen sink and hit them with it) on my last bash session (unintentionally) with bad landings, freaking tumbles and more bad landings.Currently Im running a few different CVDs. My Outcast 8s EXB has the m2c all around. My kraton 8s EXB has 2 scorched RC titanium in the front, and 2 GPM in the back. I have to say I haven't had an issues with the GPM or the scorched titanium ones. I did slightly bend one of the M2C CVD's on my Outcast but its very slight and still can be used. I used to brake the stock CVDs, at least 1 every outing it was getting on my nerves
So you bent your m2c cvd?I gave my M2C driveshafts hell with the Outcast 8s yesterday. I did everything that I could to break them (I just needed to take out the kitchen sink and hit them with it) on my last bash session (unintentionally) with bad landings, freaking tumbles and more bad landings.
Not that I can see. I did break my steering link and broke the wing mount with those very bad landings. I guess that I forgot to mention that they didn't break or bend.So you bent your m2c cvd?
Looks like the m2c driveshaft holds up better than stock!I just ordered them!Not that I can see. I did break my steering link and broke the wing mount with those very bad landings. I guess that I forgot to mention that they didn't break or bend.
I landed on one wheel (left front) in the last jump. And had some high speed tumbles. I've bent the stock driveshafts with that same landing before.Looks like the m2c driveshaft holds up better than stock!I just ordered them!
Thanks man! You make me feel more confident !I landed on one wheel (left front) in the last jump. And had some high speed tumbles. I've bent the stock driveshafts with that same landing before.
