- Mojave
- Mojave EXB
How do you set up temp warning? I've been messing around with that on 3 different CC esc's. Only one of them showed motor temp.One of the first things I did when setting it all up..
I believe it's in the motor section of the esc settings, you have to be running full sensoredHow do you set up temp warning? I've been messing around with that on 3 different CC esc's. Only one of them showed motor temp.
Except that i have three different sensored castle systems, but on 2 of them the temp warnings and displays refuse to work. I haven't been able to figure out why.Sweet.
Keep an eye on temps if you still plan on running it without fans.
In case you have not done it, I would activate the motor temp warning @180f/82c and run it sensored. It's a nice backup to have. That feature should have been activated by default IMO.
I run a 22T on my hobbywing 1650 combo The thing RIPS!
I don't think you need to be running sensored (and especially not full sensored with castle lol)I believe it's in the motor section of the esc settings, you have to be running full sensored
I haven't had any problems running sensored in my bashers after I learned how to zip tie my cables. I used to break fan wires all the time too.Except that i have three different sensored castle systems, but on 2 of them the temp warnings and displays refuse to work. I haven't been able to figure out why.
Also, the sensor cables are delicate and can't handle bashes and crashes.
I run all three of them sensorless now. They have very smooth startup anyway.
I added two 40x40 rocket fans on the motor.
Yep, cable management is definitely overlooked by many. I see alot of folks with cables and wires running wild an unrestrained..no bueno. Gets expensive quickly. Zip tie the world!!I haven't had any problems running sensored in my bashers after I learned how to zip tie my cables. I used to break fan wires all the time too.
