Looks nice!Pro line 6” double row. It’s overpriced for the quality but looks good.
It does look good, but $60... ouch.It’s overpriced for the quality but looks good.
Digitaldude80I thought I remembered some one mounting one under the windshield but can’t seem to find it. I will look into My Trick RC thanks.
Definitely overpriced, but I was lucky enough to get it as a gift and won’t really see a lot of air time (I hope).It does look good, but $60... ouch.
I wonder if something like these led light bars would work well - https://www.ebay.com/itm/163572981817
That is pretty cheap nice!$8.99 for 8 LEDS and $9.99 for LED strips meant for RC plane wingspans that i use for chassis(comes with 2, one good enough but will be damaged eventually so keep the other). And because my RadioLink has switches, two RC switch lines ($18.99) so I can turn chassis and/ LEDs off and on at will. Less than $40 CAD and decent enough set up.
View attachment 119437View attachment 119438
I love the light bars and even gave thought to ordering them. Yet there is a reason they are recommended for crawlers only.
I should note my setup is mainly to "see" the truck at night, not to see where Im going. The distance i get from RadioLink made it near impossible to tell front from rear. Easy and cheap solution.
Acquired from Amazon. If you spend 20 minutes searching, you will find 20 sellers selling the same thing with 10-15 different prices.That is pretty cheap nice!
The one thing I did like about the pro line was the way they are attached to the vehicle. Looks very sturdy. The other options may be a better investment,especially from my trick RC......If they are sturdy, lower cost and look good, that is good for meIt does look good, but $60... ouch.
I heard they were trying to make a convertible Mojave, but it looks like you did not succeedI destroyed my first lite bar mounted like that. I have 3 bodies w lite bars now, all installed at the base of the windshield and have not broken one since.
even this wreck left the bar unharmed and untouched!View attachment 119825
Other than the picture with the wreck with the roof of the mojave being distorted, I really really like the location where you put this light bar
