RC-Dude
Got a Mojave EXB with a Max6 1650kv and Hobbywing ESC. It's really scratchy when going slow. Like nearly impossible to do a slow crawl drive. Checked the whole drive train, opened all diffs. Checked all bearings and bearings on motor. All in good condition. Running a 20T pinion. The other Mojave (not EXB) with the same Motor & ESC does not have that problem.
As soon as I give more throttle it is fine. But it uses more battery than the normal stock Mojave.
Wondering if I could get a change by going to a 18T pinion. On another ESC I would try and change timing but the MAX6 Esc seems to not have that option.
Any ideas?
Before I install a MAX6 Motor for a test from another car. It's like the 4985 MAX6 motor has a bit more resistance than normal. Not sure why.
Any ideas?
