Motor conector hot
Sem V Rees
Hallo i have a question for you
My motor wire conects to a bullit conector and the in my esc but its getting rally Hot and melts my Heat shrink tubing and sometimes it doesn't make contact and than it starts stopping and Malfunction
My question is what can i do about it
And the is Black stuf in the conector and the coating is coming of
Are they OEM factory connectors?
Or something you added afterwards??
I bought it seconde hand so i do't know for sure but i think its factory
Post photos..
We'll be able to tell quick.
I'm guessing it was modified so it's not making proper contact.. Which leads to the higher resistance/heat..
Heren some pictures
I agree.
Looks like it was driven through water before and left to rust by the previous owner.
A temporary fix would be to use steel wool to clean up those rusted surfaces.
Perhaps a tiny brass brush set to get into the inner socket area to scrub it out...
or
Then apply a tiny bit of silicone grease to help prevent further rusting. AND re-cover those terminals with New heatshrink tubing.
Otherwise you're going to experience arc-ing of your motor and Kentucky Fry our ESC.
