Hi guys, in the process of reviving my kraton v2 again. I'm a little torn if I should stay with the stock diff cups and just replace them more frequently, or get the new version hot racing diff cups.
https://www.ebay.com/itm/Hot-Racing...238159?hash=item3fcf9eeacf:g:IRwAAOSwKtBdscVy
I have the old black version of the HR cups, didn't like them really. The new version has a steel bush inside and is cheaper than the previous version. The issue with the plastic cups is that there is a finite amount of times you can take it apart before the ring gear will pull the screws right out under power (blew a center diff this way). But really once you get it assembled there is really no need to take them apart.
On the other hand with the aluminum cups was that the screws would always let loose, and let the magic goo out, as well as contaminate the diff fluid with ground up aluminum. Tried threadlocker didn't really work, the stock cups have that threadlocker way about them cause they're plastic.
I'm just curious what you guys do. I'm thinking of sticking with the stock cups cause they're only $10 a piece
Thanks-
Spence
Thanks-
Spence
