- Redondo Beach
- 4x4-Mega
- Felony
- Granite
- Infraction
- Limitless
- Kraton EXB
- Mojave
- Senton 3s
- Typhon 6s
- Typhon 3s
I picked up this used V2 Infraction as a roller. It will be the base for the build.
This will be my first drag build so there’ll be a lot of learning along the way. Considering I’m gonna be using an TP4070cm motor, which is 107mm in length, it won’t fit in the original location. To accommodate this long I’m gonna flip the motor mount. It’s awesome that Arrma has holes Pre-drilled for this.
As you can see one of the battery trays needs to be removed, as well as the e-brake with mounting brackets. Still trying to figure out the layout but here’s where I’m at currently.
While I have the 30t pinion and 34t limitless spool in there now, Im gonna go with a 39t spool and 25t pinion and see what numbers I can get.
On a non-performance note, I bought a clear body and will try a sorta metallic blue type paint job with some silver and black accents. I’ll be using Tamiya PS-49 Sky Blue, PS-63 Bright Gun Metal, and PS-5 Black.
Hoping the color will turn out like this. (Note: this is not my image but one I found while searching google.
To try and help keep things straight I put in a scorched diff locker in the front (this is an older version). A couple weeks after I received this one they came out with a newer version with stronger cups and more sleek locker.
1million wt diff fluid for the rear until I get a locker for that one too.
Painting completed. However, might go buy another can of bright gunmetal to back it some more.
Also test fit the PPS motor mount.
To be continued…
To be continued…
