basher27
On my vendetta I am running the spectrum 130 amp ESC on the stock motor. I’ve been wanting to play with the ESC timing adjustments and my first question is what is the stock ESC timing this motor should be at? The default setting on my ESC is 15° but the ESC is not designed for this motor and car. Another thought that I had was if I ran a 4S battery on the stock motor, but turned down the timing, so I essentially would not allow it to over RPM and possibly a little bit less heat to the motor might help? Any and all input would be greatly appreciated
