StephenSchandelmayer
Rig of the Month Winner
All the bracing!! Love it. Might just be the angle but is the brace on the rear shock tower covering the bottom hole for the body mount?
Was a pleasure to help out..The past few day i've had to work on it have been concentrated on carbon fibre braces. Thanks to everyone who gave their thoughts and opinions on the braces, I ended up going with what was the simplest solution (in my head).
Thanks to @BashingBrian who was very helpful in giving me the technique he uses to make his carbon braces as well as ebay links to where to buy the bits, top man
I bought all the products Brian suggested and began work. I marked the length of carbon i wanted uses some masking tape, and then went about cutting them to length using a Dremel with a cut off bit, i did this outside with a mask on to try to reduce the amount of carbon dust i breathed in.
Once i had them all cut, i filed the ends down as flat as i could get them.
Then i began making up the thread inserts for each end of the carbon rod. This comprised of a piece of m5 threaded rod stainless, two m5 nuts tightened down on each other, these work both as a stop so the rod doesn't fall inside the carbon tube and so you can remove the m5 rod if desired, and lastly 3x m5 threaded inserts. Should look something like this.
With a small grinding(?) head on the dremel i then went about sanding/grinding the inside of each end of the carbon tube, in order to give our adhesive/bonding something to bite into. Once done i cleaned each end out with a cotton bud dipped in 99% alcohol.
I decided to grease all the bits that i didn't want stuck together in the hopes it would come apart easier, so i greased the very end of the threaded inserts where the threaded rod would poke through if it were wound in enough, and greased the double nuts as well.
I put some masking tape on the carbon tube to protect it from the bonding agents.
At this point you should have something that looks like this.
At this stage i mixed up the bonding agent, in this case JB Weld, using a small applicator (a sanded down wooden skewer) i coated the inside of the end of each tube as well as all over the brass coloured threaded inserts, i put the pieces together, wiped any excess off straight away with a tissue and then removed the masking tape while the JB Weld was still wet.
I left it for 24 hours to cure, went about removing all the threaded rods and cleaning up any dried excess JB Weld as necessary. Then i drilled oput the holes on the shock towers to 5mm where needed and assembled it all.
I'm very happy with how it all turned out, and enjoyed the process quite a lot, and am now thinking of adding another four supports
Only thing i am concerned about is where they mount directly to the shock towers there is no plastic there to help with the shock absorption so in a big hit they may just shatter, one way to find out right?
Yes yes, I’m finally having less questions for them I have the ender 3 S1, so very similar. Let me know if you have machine specific questions, or about setup! It’s a fantastic machine.This just turned up
So no doubt i will be bugging Tex and all the other 3d printing aficionados with really annoying noob questions in the 3d printing section for the next few weeks or months.
It’s pretty great! Looking good.Not much new to report, just been busy modeling, im obsessed with this 3d printing malarkey, its amazing.
What will you print them in at the end?
Sounds good.Honestly i don't know yet, im gonna start a thread in the 3d printing sub section and ask for some advice from people more experienced who have been there done that and know what they are talking about. From what little i know im guessing it will be some kind of TPU or Nylon or mix of the two.
Looking at that picture those motors look so dinky for the size of the rig.
You’re talking about the chassis side guards? I’d do nylon.Honestly i don't know yet, im gonna start a thread in the 3d printing sub section and ask for some advice from people more experienced who have been there done that and know what they are talking about. From what little i know im guessing it will be some kind of TPU or Nylon or mix of the two.
Would love to see some vids of it running.
Difference is you have 4 wheels in the back gripping! I hope this thing works good for you I'm very excited to see how it does and what you think after all the workIf all goes well and i get some time to work on it, I'm hoping to get it running this weekend.
I'm expecting the 6s servosaver arm to break on first collision. As that was the only thing on this build that was really bodged.
And any hope of it wheelieing (as i had at the start of the project) has gone straight out the window. It weighs almost the same as @StephenSchandelmayer 's Goliath with only a fraction of the power.
