There are a few others here having a similar issue. Mine has been smooth as butter tho.With the truck off it rolls butter smooth.
Runs completely normal for a bit then it'll bind so hard at low speeds it'll lock up.
Hit the throttle, no issues, then binds up. Gear mesh looks ohk.
Castle XLX2 1100KV combo 34t 39s. Running uncensored.
Any ideas?
Thanks guys!
When you run it unsensored the ESC knows nothing about where the rotor is in relation to the stator. Plug in the sensored wire and run it the same way. See if you still get cog.. My money says NOPE!Hmm.
Just swapped out the 39 for the 34 and there was no issues at all.
Running sensorless due to conflicting info. Seems half say it's fine, others say it's not.
I'm still a noob.
You normally want a sensored motor for smoothness at low speeds, and a sensorless motor for higher speeds. That's why Smart Sense on Castle ESCs is great: it runs the motor in sensored mode at lower speeds, and changes to sensorless mode at higher speeds. And it's all done automatically.Hmm.
I'm still a noob.
