It’s here... red and white of course!
Now you can pit the Hoss! ?
Is the truck that front end heavy? Seems like it wants to nose dive constantly. Maybe something not letting the drivetrain roll freely causing a breaking effect? Just seemed like you had to gas it on landings to not nose dive, usually it's the opposite have to break to not land on roof?Honestly, the Associated might be better. I haven't decided yet.
Hi all.
Mt10 was my go to option but... I did join to mt10 group on FB and guys are struggling to get replacement arms for their trucks where the original arms failed very quickly. No chance to get the helion replacements too. So atm they been left with broken trucks.
Cheaper truck, looks quite good, handles perfectly but non programmable esc with razor sharp brakes is a big no no. Also the stock radio is a bit crap. I mean it works as it should, it's responsive and does the job but it's plasticky, big and low on quality. Same radio came with my element sendero and I swapped it straight away.
Then I started eyeing out the arrma granite.
Razor RC posted some vids with v1 granite and I was seriously excited about the new V3 release to the point I almost pre-ordered one for myself but... I've seen that guys lost their wheels on the first run which is not a big deal really as it's easy to fix but damaged shock tower along with shock end without excessive abuse is not acceptable really. Also stock A arms are not holding well :/ A bit disappointed.
Razor RC, I'm following your feedback, will see what will happen next
Hi all.
They are still using the same part for the driveshafts, so I doubt anything changes there ??Nice one razorrc. Another point towards granite.
So in case of breakages we've got some cheap shock caps upgrades, shock towers can be easily reinforced with some piece of aluminium U section, better A arms available from RPM..
and the last thing (I hope it is the last thing) is the v2 driveshafts problem. Are they holding strong so farnon V3?
My friend has V2 granite and he's fed up with it already due to drive shafts being so weak.
Also how's the new slipper compared to the older version?
I've seen several YouTubers (including RazorRC) say the Traxxas Maxx is one of the most, if not the most durable RC out of the box. If durability is the priority, it may be the best choice. I've thought of getting the Maxx, but judging from the videos, I just don't like the way it handles. I have a Granite, I've needed quite a few upgrades to improve durability, but at this point it's quite solid.I feel like I made a mistake and should of ordered a traxxas max instead of granite judging all the issues being raised in this thread . I already have a brand new broken kraton exb and I just want something that will run without breaking so quickly
