Hello,
I have problem with my Arrma Typgon 6S BLX. Rear right dogbone is popping out from diff output cup and I don't know why. Only rear right, no problem with left one.
What have I already done to identify the problem:
1. I swapped front/rear differentrials to eliminate problem with diff outdrive.
2. I swapped left/right dogbones.
3. I measured rear dogbones (AR310456), they lenght is 91mm pin-to-pin as in the spec.
4. I swapped left/right wheel axles (AR310431) with bearings.
5. I measured left/right turnbuckles (AR330214)
The problem is only when wheel goes up and rear suspension arm is lifted fully up (full shock compression). It is not connected with droop screw.
I've searched forum for solution but all posts were about front dogbone popping out. Can you help me?
