- Location
- TAMPA, FL 🇺🇸
- Granite
- Infraction
- Kraton 6s
- Notorious
- Typhon 3s
#ARRMA #FAMILY - Any suggestions on any upgrades on my new #ARRMA KRATON v3 Model?
Guys just FYI I saw that on RC crawler forums and it looks true: that Eco power servos are just rebranded JX, so here is the original, which could be bought 30% cheaper (still decent servo): http://www.jx-servo.com/en/Product/WATERPROOF/426.htmlI really like the Eco power WP120t servo. It is a coreless ,water proof high torque servo with all metal gears and works great as an upgrade for the stock kraton servo and the price is awesome for the quality that you get with it. Here is a link
https://www.amainhobbies.com/ecopow...00hgA62QX8IsHRjb6cGPdYwjhjPlqSDMaAhcDEALw_wcB
I recommend going with the eco power wp120t servo. Its waterproof, Metal gears, dual bearing, high torque and is coreless. It is definantly an upgrade when replacing your stock kraton servo. When running at 6v you get 337 oz.-in. Of torque and .11 transit speed wich is awesome but even better is at 7.4v you get 400 oz.-in. Of torque and .09 transit speed. And for the price it is an amazing value. I love using this servo for my v4 kraton. Heres the link.
Is there a reason why you’re changing the hexes?Many thanks -WoodiE! I just scored a brand new 2018 model of the #KRATON 1/8 BLX 6s truggy!
Here are a few of the upgrades that I am going to do right out of the box when I get this Saturday
First changing the tires to the - Trencher X 3.8" All Terrain Tires Mounted - Pro-Line Racing
17mm Aluminum Wheel Hexes Black Nuts & Pins Hex 16.5mm
New T-Bone Racing Front Bumper:
New Servo Aluminum Mount from Voltage RC:
Skid Plate rear 6061 Aluminum:
View attachment 46287View attachment 46288View attachment 46289View attachment 46290
b/c my buddy had an extra pair for freeIs there a reason why you’re changing the hexes?
What’s the advantage over the stock ones? Those are a PITA to replace for no apparent gain?b/c my buddy had an extra pair for free
Already placed my order for the following HopUs from #VoltageHobby / #Horizon Hobby & #T-BoneRacing for my new #ARRMA #blx #6s #KRATON!
Aluminum - Servo Mount
Aluminum Finish - Skid Plate Set
Aluminum Finish - Servo Clamp
Trencher X 3.8 All Terrain Tires Mounted (2) Pro-Line RC Wheels/Rims
Aluminum T2T Tower to Tower Chassis Brace
10074 - TBR Thrasher Front Bumper
10109 - TBR Aluminum T2T Tower to Tower Brace
It will have no benefit compared to stock servo - same torque, same low speed.I think I just might go with this one: Anyone used this model yet in the Kraton 6s BLX Monster truck yet?
Savox SW-0231MG Waterproof High Torque Servo w Aluminum Horn :
Go with Savox SW-1210SG (20kg 0,15s) if you want expensive or with either DS 3235 (32 kg 0,12s) or JX Servo - JX CLS5830HV (25kg 0,11s) / JX WP43 (35 kg 0,13s) if you don’t want to spend a fortune for that.
why doing V4 motor ? what's the difference? and diff mount?For a V3 I would do tires, V4 motor and diff mount, sealed bearings and servo.
He meant V4 motor mount and diff mount.why doing V4 motor ? what's the difference? and diff mount?
Yeah I kind of worded it funny.He meant V4 motor mount and diff mount.
Nope, you need only servo, everything other will fit from your existing rig. Bec could be an option to get 7,4v instead of standard 6v to obtain more torque, but nobody actually get bothered with it.I understand now, when I burn out my stock one, I will be upgrading to the Savox SW-1210SG (20kg)! Do I need to grab the following parts with it?
