Luigibell78
- Limitless
- Outcast 4s
- Typhon TLR
- Thread starter
- #21
You have any pictures of this bearing support system from arrma?Have those also......
I felt the same way about the RCAWD shafts. A modest upgrade at a modest cost.
BTW, I tried the Ball Bearing Drive shaft support found on the V2 Infr, Fel.
Do yourself a favor and don't get them. If you have a V2, take it off ASAP. IMHO. The bearings lasted about 2 Speed passes at only 84MPH in my LIM. Bearing Seals exploded on both bearings, and bearings got loose and scored the Shaft. Did more damage and made a crap load of noise. Waste of $12. trying it out on the stock Lim. rear shaft. Just take them off on your V2's, Get a better rear shaft. I felt speed took a hit also, from the friction against the shaft. What was Arrma thinking. That Band-Aid fix is useless in the V2's.
I looked at the exploded parts view of the v2 infraction and i didn't see anything different other than that handbrake thing.....
