Premium members don't see ads. Click here to upgrade.
senton 6s suspension setup
Ethan_waite
Ontario, canada
Nero, , Senton
Hi! I recently got myself a senton 6s and it's made me fall in love with arrma lol. However, I noticed the front shock seem to be significantly easier to compress. Anyone know what the stock shock oil is? And what oil are you guys running for general bashing and a few decent sized jumps?
chevys10zr2003
ArrmaForum Fan
Minnesota, USA
Kraton 6s, Senton, Typhon 6s
You can look up the manuals online from here. https://www.arrma-rc.com/support/downloads/SENTON/BLX/2017
The V1 like yours is listed as 550cst. The V2 has 800cst in the front and 600cst in the rear. Most people run Team Associated shock oils and they are listed in wt measurements as well as cst measurements. I would honestly try the weights that they have in the V2 as most people tend to go a little heavier weight than what stock is.
joostin420
MA/NH
Fazon, , , Senton,
Are the weights the same for the v3? Should you go heavier; if so which weights?
jorroru
New Member
En el manual v3 lleva 550
1.lo que Le falta son las fundas botas
1.las del v1 se podrĂ­an utilizar?
Similar threads
