NewKratonuser0311
- Points
- 103
- Infraction
- Limitless
- Kraton 8S
- Typhon 6s
Any suggestions on a solid 1/5 scale servo for my exb kraton.
Have you used one? I don’t love it. It seems plenty strong and durable, but slow as molasses.^^^
+1
That Raminator servo seems to be the way to go. The price is right. Many 8s guys are running them. Just need to use the extended Rx tray, Servo mount with this True 1/5 scale servo. The stocker is Not a true 1/5 scale servo. The first mistake Arrma made out the box with the 8s line.
And I would never give HH/ Spektrum over $200, for one of their servo's.
https://www.primalrc.com/product-prpre005
Do you run the 9110 or 9120? How do you like it?
That’s faster but weaker than the 9120 I think.im running the 9110
Yeah, and I would agree that faster servos would come at a higher price tag. If the rig had a a better designed calculated steering throw angle along the steering horn and belcrank, Speed would be way better. A better quicker throw angle. Better more efficient leverage.Have you used one? I don’t love it. It seems plenty strong and durable, but slow as molasses.
That Spektrum you bought should be one of the better options out there. I see no reason to ditch it for something else.ill keep you posted,all my parts are here,i had a blast yesterday with the wife’s kraton,in your opinion whats the best 1/5 scale unit servo
will keep you updated i plan on running it hard.i already broke both lower a arms on the kraton.repaired and up and runningThat Spektrum you bought should be one of the better options out there. I see no reason to ditch it for something else.
advice?Alloy front arms was not the answer.
Let us know what other more expensive parts end up breaking now with the alloy lower arms.
Only my opinion.
Others may also agree. IDK.![]()
Return the aluminum and put the stock plastic arms back on.advice?
ok thanks it all new to meReturn the aluminum and put the stock plastic arms back on.
Yes, great choice of wheels. Just heads up you may have to drill the middle hole a little bigger to fit the Kraton. A simple step drill bit should do the trick.ok thanks it all new to me
so i did good with wheel package right
