Or maybe go ahead and buy a quality servo and keep stock one as spare?I would still run it at 7.4V until it failed and then buy a quality servo
I think this happened to me. New truck less than a month old and servo quit, and I hadn’t adjusted endpoints. Dumb thing is I had watched razors video about out of the box calibrations.stock servos fail because the no one takes the time to set the endpoints
Manual shows 7.4 is default but I haven’t verified that it’s actually set to that.I'm also one to believe that the BEC is set to 6.0 stock.
I might be an idiot, but I don’t plan on staying one.@JustAnOutcast The take away being you learned from your lesson. Most don't (and refuse!)
Had a small feeling I might have been wrong (and that's okay!) I wonder if different ESC's are set to different BEC's? ... all these acronyms make me want to take a BMW to KFC ...Manual shows 7.4 is default but I haven’t verified that it’s actually set to that.
I might be an idiot, but I don’t plan on staying one.![]()
Yes. I’ve read so much (too much???) about the S652 that now I’m spooked.Is this for the outcast?
They are.. still rolling strong in the felony and mega, weird huh, I expected them to go pretty soonManual shows 7.4 is default but I haven’t verified that it’s actually set to that.
Thanks for the recommendations. I’ve already reached out to ProModeler with questions but haven’t heard back yet. Will look into the others as well. Saw a ProTek PTK-130T at LHS today for $89 but haven’t done any research on that one.AGFRC, Perfect Pass, Reefs RC, and promodeler make good servos.
I also forgot protek is pretty good too.Thanks for the recommendations. I’ve already reached out to ProModeler with questions but haven’t heard back yet. Will look into the others as well. Saw a ProTek PTK-130T at LHS today for $89 but haven’t done any research on that one.
I’ll try backing it down one more, thanks. I had changed it from the default 22.5 to 15 to help with motor temperature…While you are at it, change motor timing to 11.25.
Yet another reason for ESC failure rate the way it is.
Have you made changes to any of the other default ESC settings?They are.. still rolling strong in the felony and mega, weird huh, I expected them to go pretty soon
Having thought on this way too much (compulsive over-thinker here) this is good advice. Keep everything stock until warranty runs out…If it is under warranty, I don't think you need to lower BEC. If you are buying a new servo once yours quits, buy a good servo and have the stock as spare. Is this for the outcast? AGFRC, Perfect Pass, Reefs RC, and promodeler make good servos.
