slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
By all means, if you're happy with them, why not? If you were to stick with TRX batteries and charger, you'll need their big charger, 2973 which is 4s (x2) capable. For the limitless you would be using 2x4s to make 8s. So the charger only need be 2x4s capable. That's assuming you'd like to stick with TRX. I like their batteries TBH, they hold up well long term, and easily put out as much power as the Spektrum so called 100C packs. You can add TRX connectors to any esc, or just buy a VXL8S. Not the best esc but, mine and my brothers are both still working fine after 2 years so many options out there. Like I said before, lipo batteries and chargers really aren't as complicated as Spektrum and TRX will lead you to believe.
Yup a lot of the ISDT chargers will automatically detect the voltage and apply the proper setting for that, the hardest part is setting the charge rate.
