Assuming this is for a Kraton 6S, my connector of choice would be IC5 or XT90. Both are easy to solder and de-solder when necessary.Here's a different question, for a single 6s brick set up what would be your plug of choice?
I use a mini torch and heat up the bullet, fill with solder and jam the wire in whilst it’s still hot. Then assemble as normal.
Here you go This is all just Kester 63/37 solder in all different gauges. I like the 0.040" personally but whichever is your preference, they should have it.The Netherlands of course, Mr. Turner.
Now that we're talking about lead free solder....
Will i be able to melt the awful 99% tin with a lead pellet and solder with that?
That would be a Eureka moment.
I might try that.
No way! Are you kidding me?
It worked!!!!
It sounds like you have enough but, should you ever find yourself needing more or if you know someone who is looking for a reliable supply of leaded solder, you can always direct them here.Same problem in Germany.
They restricted the commercial use of leaded solder and for whatever reason all stores stopped selling leaded solder to private individuals, even though that has not been banned.
I just order my trusty Kester leaded solder from Amazon.com, got a few kg that should last me to the end of my hobby days
