I don’t have one of these but the videos don’t seem odd. When you turn sharp and let off the throttle you can snap oversteer like that in anything because you transfer weight to the front, unload the rears, and the turn hard enough to break the back end loose. Don’t do that. I want to see a turn where you gradually roll into the throttle. If the rear snaps, counter steer but do not back off the throttle.
Also - the suggestion above to clean the tires with simple green is a good one. Do that. Wipe the rears down really well with Simple Green. Then get some speed on. Use some throttle. Get that back end out and see if it will hold a drift. If it starts to snap then hold the throttle steady and let it spin out.
Lastly, check your ESC settings and tell me what your drag brake is set to.
