- Felony
- Kraton EXB
- Senton 3s
First time i had it all apart.. Was changing bearings and servo.. Stripped the grub screw!! F**K
IDK WTF IM DOING!!!
IDK WTF IM DOING!!!
Yep!!On the pinion?
Key is to heat up that threadlock before attempting to remove.Yep!!
It's a bit nerve-wracking, for sure. Just take your time and try to enjoy the process. It's all part of the hobby...Didnt bend the shaft.. F**k guys!! My first big job and i screwed up.. Too green for this sh*t!!
You get it out yet?Someone else mentioned those.. Im so frustrated rn!! A lot a good it does to try to take care of the rig.. I just tear it up more than bashing does!!
I feel you, just did a conversion to 12mm to use on road tires and stripped one of the grub screws on hub. Spent about 30min trying to get it off and just gave up.Nope had to walk away for a bit!!
I got it out.. Scratched up the motor mount plate but f it.. I ordered another one!
