I agree, but in the world of RC now (mostly preassembled RTR’s) that’s to be expected, unfortunately. FWIW, I never ever run a rig without first checking gear mesh, wheel hexes and nuts, or without setting endpoints. I manually manipulate the diffs (outdrives and input cups) to make sure they’re not way out of whack and if they’re close to ok I run a couple or three packs through before I remove, reshim, and refill. New gears need to “run in” IMO, unless you just want to do it twice in a very short amount of time. Could they be perfectly assembled at the factory by teams of skilled, knowledgeable workers? Of course they could, and the price would likely double. Back in the day when it was you building the thing from a box of parts with a great assembly manual, then you knew what every clearance was, and every nut and bolt was good when you were done.I calibrated the esc and the front was drooping a little so I did a little adjustment to the shocks to get it off the ground. The end points were short if anything so I didn't mess with them. Am I the only one who thinks it's a bit silly to have to tear an almost $1000 machine apart in order to even use it? Would you tolerate that with your TV, phone or any other thing that's relatively high grade? I understand that wrenching is part of the fun but it isn't THE fun. Driving is THE fun. If this is the norm we as a group are tolerating too much mediocrity from Arrma.
ThisWe NEED kits.
I understand you are frustrated your toy broke on the first outing, I would be too.I calibrated the esc and the front was drooping a little so I did a little adjustment to the shocks to get it off the ground. The end points were short if anything so I didn't mess with them. Am I the only one who thinks it's a bit silly to have to tear an almost $1000 machine apart in order to even use it? Would you tolerate that with your TV, phone or any other thing that's relatively high grade? I understand that wrenching is part of the fun but it isn't THE fun. Driving is THE fun. If this is the norm we as a group are tolerating too much mediocrity from Arrma.
Thank you so much everyone, I absolutely love all of the engagement in this forum. A little update. HH sent me a new set of cups, the front diff looked awesome and was tight as a drum. I put 50k oil back in it and it drives awesome. I ran two packs through it at a park in the freshly mowed grass and on a long dirt driveway and it's so fast and controllable. I'll probably put some heavier fluid in the rear next time I have stuff apart. I think they put the wrong droop screws in because if the rounded head is down toward the chassis there's no way to adjust them. I attached a picture. After doing some research I found some that have a hex in the other end too, so I have those on the way.
That’s what I do as wellPs.
adjustment from underneath is a bit easier if you have a ball head hex driver. That way, you can angle it in there.
+1The rounded head is supposed to go toward the chassis so the installation is correct here. Adjustment on these type of screws is from the underneath (undesirable).
The screws the other guy’s mentioned above are better and can be adjusted from the top.
cheers,
kev
I recommend using Oil in the Rear diff, that is aprox half the CST of the Front diff. ( 20-30K) As a start. Then drive it and get comfortable with it. Too thick in the rear will make these Pivot Ball type platforms harder to steer. From my exper.Thank you so much everyone, I absolutely love all of the engagement in this forum. A little update. HH sent me a new set of cups, the front diff looked awesome and was tight as a drum. I put 50k oil back in it and it drives awesome. I ran two packs through it at a park in the freshly mowed grass and on a long dirt driveway and it's so fast and controllable. I'll probably put some heavier fluid in the rear next time I have stuff apart. I think they put the wrong droop screws in because if the rounded head is down toward the chassis there's no way to adjust them. I attached a picture. After doing some research I found some that have a hex in the other end too, so I have those on the way.
Yea, I’ve gone as far as drilling a small hole in the upper arm to get the driver straight inOne thing I always thought was dumb was that you have to remove the upper a arms to properly set the droop on the front.
I remember years ago someone posted pics on Facebook showing that they did this to their car and so many people were yelling at home for weakening his a arms I'm like wow some people are complete morons.Yea, I’ve gone as far as drilling a small hole in the upper arm to get the driver straight in
That’s what Raz doesYea, I’ve gone as far as drilling a small hole in the upper arm to get the driver straight in
+!One thing I always thought was dumb was that you have to remove the upper a arms to properly set the droop on the front.
I take the shocks off at the top then you can get to the droop screws easerOne thing I always thought was dumb was that you have to remove the upper a arms to properly set the droop on the front.
