Kraton To hot šŸ„µ to drive letā€™s upgrade
Fishtank
work the hardest when no one is watching
Arizona
  1. Infraction
  2. Kraton EXB
I tell you what this forum motivates me to make upgrades! šŸ˜‚šŸ¤£šŸ˜‚ seeing all the badas$ rigs. So Iā€™m adding HR motor mount and top. Changing all the diff oils 60k front 500k center 30k rear. Installing castle monster X with sensored 1800Kv motor. Iā€™m going to start with a 17T pinion and go from there with temps. Going to run a powerhobby dual fan gif cooling.
Right! šŸ˜‚ I think some of these peeps are either Arrma or Castle motor employees!! :ROFLMAO: Arrma Forum ROCKS!! šŸ‘āœŒļø
The deficit is real! For me anyway! Woke up and spent about a hundo and a half on JRC yesterday. $80 worth of other online orders be here M-W and went to the local Hobbytown this afternoon and spent another $75. Took my wife and daughter to Outback to offset a little. Everyone happy except TruistšŸ˜‚šŸ˜‚
Definitely not a forum to be on if trying to save $$$:ROFLMAO:
these fans are awsome, i have run more than 60 packs, zero issues.
awsome build, love these wheels also.
1600-1800kv is sweet spot for these Kratons.
More than 1900kv is for talion if you ask me.
For what itā€™s worth, the 1512 is a little small for the Kraton and itā€™s only rated for 4S. Most people stuff a 1717 sized motor in a Kraton with the MMX8S.
You might want to check the specs. Itā€™s 6S rated. I had the Max6 with the 1650Kv motor in it already didnā€™t need a kraton that fast. Took it out and put it in my Infraction. You have to read the fine print,
The ESC is 6S rated.
The 1515-2200 motor that you circled is 6S rated:
https://www.castlecreations.com/en/1-8th-scale-1/1515-2200kv-sensored-motor-060-0063-00
The 1512-1800 motor that you mentioned ordering in your first post, which is shorter than the 1515, is only 4S rated:
https://www.castlecreations.com/en/1-8th-scale-1/1512-1800kv-sensored-motor-060-0062-00
Glad you said something. I backed out of the deal. No wonder it was such a great deal.
Kept telling me itā€™s new in the box said it was 6S.
