Big Rock Too heavy? Shock suggestions.
ransom 65
Been upgrading my big rock. Right now it's sitting at 12.6 lbs. got the 2050/150a combo in it with a 15t pinion, plenty of aftermarket cooling, full metal drivetrain, plenty of chassis protection, etc.
I have 6s shocks I have to slap on. What weight shock oil, spring weights and adapters can I use to make it work with the stock stock towers? Is it too heavy for 6s shocks now? What setups would you recommend.
Tekno makes good springs wide range of different lengths and spring rates. All that extra weight. Go up at least 2lbs on spring weight. Maybe more.
Is that weight with batteries and body and wheels? Depending on that, I'd say you are pretty close in weight to a modified 6s Kraton in weight, i would have thought the 6s shocks and springs should be able to cope with that weight fine.
