Yes, the gear is actually in our freezer now. Will try it. However what do you use to push the bearing down the gear ? I was thinking of buying some hollow 10mm pipe and hammer it down or i don`t know. There must be a tool designed for both purposes somewhere.For installation:
Take the gear and put it in the freezer.
Take the bearing and heat it up with a heat gun.
Wala...
For removal, use 2 flathead screwdrivers and twist pry away evenly.
I can't help on getting the bearing off the shaft without damaging it. But for installing stubborn bearings on to shafts, I use a deep-dish socket that is the size of the inner bearing race. Put the socket, drive end down, on a firm surface, and then tap the gear lightly on the end to drive it into the bearing. Or you can do the reverse, where the gear is on the firm surface and you use the socket to bush the bearing on the shaft. I've done it successfully both ways.Yes, the gear is actually in our freezer now. Will try it. However what do you use to push the bearing down the gear ? I was thinking of buying some hollow 10mm pipe and hammer it down or i don`t know. There must be a tool designed for both purposes somewhere.
You don't want to know!! Bearings have a very prominent duty to perform.. when one seizes, fails, or grenades.. It can potentially be Catastrophic!!I noticed one of the bearing (the inner one) moves with more force required than the other. I`ve no idea when it becomes bad. I just feel a tiny friction inside of it or something like rubbing. Could be that i pushed the seal into it when removing. Shouldn`t be a big deal right ? What`s the most that can happen ?
Wala?Wala...
I think I’m approved to use the incorrect American English version of voila..Wala?
Haha I was reading the "a" like in "hat" - thought it was an acronym for something I didn't understand... even Googled it figured it was nothing to do with the worldwide Australian labradoodle association!I think I’m approved to use the incorrect American English version of voila..
