Mit Snori
My cars a standard 3s BLX vorteks. Stock motor and ESC. Iām not considering buying that motor Iām just using it as an example to help me understand how it works. Thanks again.
Am I right in saying the larger the can , the more amps the ESC will need to pull and the bigger the battery you'll need buddy . ?A longer motor can and/or a bigger diameter motor can will have more torque but also will be a lower KV rating. The added torque is to allow you to run bigger gearing for speed but still not heat up as much because of the lower KV rating. As far as the KV rating goes: Battery Voltage times KV = RPM(Volts x KV=RPM). Stock 3200kv motor running on 3s goes like this: 14.6x3200=46720RPM. 2750kv motor: 14.6x2750=40150RPM. Lower Max RPM means less heat, but also less top speed which means you have to gear up to get your top speed back while still having a lot of torque to turn the bigger gearing and get the heavy rig started out faster.
Hope this answers your question and is not too confusing.
Yes, naturally the larger motor can will pull more amps. But the stock BLX 100 ESC can handle a 3670 size motor without a problemAm I right in saying the larger the can , the more amps the ESC will need to pull and the bigger the battery you'll need buddy . ?
I'm asking as this is new to me also but I try to do my research as much as possible.
When I was racing years ago brushless motors when literally just about to hit the market and was a unknown . Then I quit , so last motor is ran was a modified 8 turn brushed reedy .
Awesome thanks for letting me knowYes, naturally the larger motor can will pull more amps. But the stock BLX 100 ESC can handle a 3670 size motor without a problem
Hi Kla - very concise Thankyou! For clarity where does the 14.6 figure come from? I thought the voltage on a 3S battery was 11.1v - No doubt you will shortly educate me! (Thanks for helping - appreciate your knowledge).A longer motor can and/or a bigger diameter motor can will have more torque but also will be a lower KV rating. The added torque is to allow you to run bigger gearing for speed but still not heat up as much because of the lower KV rating. As far as the KV rating goes: Battery Voltage times KV = RPM(Volts x KV=RPM). Stock 3200kv motor running on 3s goes like this: 14.6x3200=46720RPM. 2750kv motor: 14.6x2750=40150RPM. Lower Max RPM means less heat, but also less top speed which means you have to gear up to get your top speed back while still having a lot of torque to turn the bigger gearing and get the heavy rig started out faster.
Oops! I meant 12 6 volts not 14 6. Each cell fully charged is 4.2v per cell. For a 3s battery, 4.2v x 3s = 12.6v, so a fully charged 3s lipo is 12 6 volts. Check your battery charger voltage the next time you charge your 3s batteries. Fully charged should read 12.6v.Hi Kla - very concise Thankyou! For clarity where does the 14.6 figure come from? I thought the voltage on a 3S battery was 11.1v - No doubt you will shortly educate me! (Thanks for helping - appreciate your knowledge).
Hey man, you have a ribbed motor, and a heat sink wonāt make solid contact with the motor so it wonāt work as well as a smooth motor. Ribbed motors have the heat sink built in, thus the ribs. Best to use a fan mount and no heat sink. One like thisā¦Final peice of the puzzle came today finally small but important my Surpass rocket fan . And Jesus these move some air for sure .
Quite impressed.
Now I should be good for temps with the new motoView attachment 255532View attachment 255533View attachment 255534
Hey buddy thanks for the heads up I'll get one ordered but having said that I do use Geelid Extreme Thermal pads also when fitting heat sinks anyways to improve thermal conductivity.Hey man, you have a ribbed motor, and a heat sink wonāt make solid contact with the motor so it wonāt work as well as a smooth motor. Ribbed motors have the heat sink built in, thus the ribs. Best to use a fan mount and no heat sink. One like thisā¦
When that one breaks get this one as itās much sturdier. Smaller but stronger. It also has places to install m4 screws on top of it so it doesnāt get thrashed while sliding on the lid. The picture doesnāt show them but they are there. Just make sure to get the exact part number. I have one on my parts bin typhon and itās proven to be solid.Getting there Chrisā¦. Just waiting on a 14ml hex for 4th wheel. Fitted the wing as the body mounted one has slowly torn off from bad landings etc etcā¦.
With the lid.
Is that the outlast wing buddy ?When that one breaks get this one as itās much sturdier. Smaller but stronger. It also has places to install m4 screws on top of it so it doesnāt get thrashed while sliding on the lid. The picture doesnāt show them but they are there. Just make sure to get the exact part number. I have one on my parts bin typhon and itās proven to be solid.
Awesome buddy what's your thoughts on the wheels and tyres , I love mine .Getting there Chrisā¦. Just waiting on a 14ml hex for 4th wheel. Fitted the wing as the body mounted one has slowly torn off from bad landings etc etcā¦.
With the lid.
Specifically the 4s outcast wing.Is that the outlast wing buddy ?
Is there a shim on your diff on the non ring gear side? I do not like any play at the composite ring gear and differential as this is what happens. If there is a shim on the opposite side from the ring, remove it and then check the mesh. It may even need a shim on the ring side to tighten it up. As you run in the car youāll need to check it every so often.Well forgot to post yesterday some bad news guys 4 minutes in to a 3s pack I hear a clicking noise .... Decided to stop right there as I knew it didn't sound like something good was happening.
Came straight home and stripped it down at first thought it might have been the spur and pinion.
Nope that's all good
Stripped the diff case housing and wallah stripped input . But crown seems ok . So my question is am I ok to just order a input and noView attachment 256232View attachment 256233t the crown gear and should I upgrade to a metal equivalent on both ????
Ideally I need the cheaper option right now but wondering is this a common occurrence.
Here's the pics and thanks in advance
ChriswithaC
So crown gear is spot on but input is toast so ordered a new HD input .
Yeah I thought it looked big when it arrived but with these ridiculously big Tomahawks tyres it looks ok scale wise! Hear what your saying about flimsy. It does feel a little loose. - not had chance to drive yet as only got 3 functional wheels. Certainly arenāt belted but seem grippy and chunky in the hand. Quality seems good.When that one breaks get this one as itās much sturdier. Smaller but stronger. It also has places to install m4 screws on top of it so it doesnāt get thrashed while sliding on the lid. The picture doesnāt show them but they are there. Just make sure to get the exact part number. I have one on my parts bin typhon and itās proven to be solid.
Thanks buddy I'll check it out this evening as the input gear should be here tomorrow.Is there a shim on your diff on the non ring gear side? I do not like any play at the composite ring gear and differential as this is what happens. If there is a shim on the opposite side from the ring, remove it and then check the mesh. It may even need a shim on the ring side to tighten it up. As you run in the car youāll need to check it every so often.
Another thing that can help cause this is landing on power after jumps and transitioning between traction surfaces on high throttle. Also, look closely at your spare gear. See how there is compressed grease āpasteā (which happens when fine dust gets in and mixes with the grease) in between the teeth? That can prevent the input gear teeth from fully seating. Itās a good idea to service the differential often, especially the rear one which gets the most stress. A lot of people say to not mix-and-match a new input gear with an old diff. But Iāve never had any troubles with it as long as the differential is still in really good shape. Make sure to get all that compressed grease out of there.
